Avon ZZS: le graal du pneu ?
jerome_tlse
Message par jerome_tlse »
caterham vient de changer de fournisseur de pneus, passant du CR500 à l'avon ZZS.
c'est un nouveau pneu qui semble t'il possédé un grip très proche des semi slicks classiques type R888 ou A048 tout en offrant une meilleure resistance à l'aquaplanning, gros point faible (avec l'usure).
dispo dans les tailles lotus...Q2 2016... avec un peu de retard donc
The Avon ZZS is a tyre range developed to offer outstanding all-round performance in both wet and dry conditions and both on the road and on the track. The unique symmetrical and directional motorsport derived tread pattern was designed to maximize water clearance while maintaining superb dry weather performance through excellent tread block stability. The ZZS is fully road legal DOT marked and complies with all EU Tyre Labeling regulations.
New for 2015 the Avon ZZS will become the single control tyre for the official Caterham Roadsport, Tracksport and Supersort race championships.
•Superb dry and wet weather performance
•Fully road legal, DOT Marked and EU Tyre Labeling compliant
•List 1B permitted race tyre (2015 onwards)
•Full racing tread compound
•Designed by the Avon Tyres Motorsport Technical Department.
•Ideal championship control tyre
•Tyre construction utilises materials found in GT, F3, Formula Ford and other world class forms of motorsport.
•A road legal racing tyre
We have stock available in two sizes of ZZS
185/55R13
215/55R13
245/50R13
195/50R15
245/40R15
We are currently developing the following sizes:
195/50R16 – Expected Q2 2016
225/45R17 – Expected Q2 2016
Re: Avon ZZS: le graal du pneu ?
La question est maintenant de savoir si ces deux dimensions sont effectivement commercialisées :voyons:
jerome_tlse
senior a écrit :La question est maintenant de savoir si ces deux dimensions sont effectivement commercialisées :voyons:
non, pas de nouvelles suite discussion avec gerard de pneu shop.
