Nouvelle Evora S
Zdesign
Nouvelle Evora S
Message par Zdesign »
Ma futur :love:
bon c'est vrai elle prend un peu de poids :x
Ahead of the official unveil at the Paris Motor Show on September 30th, Lotus announce the latest evolution of the award winning Evora – the Evora S and Evora IPS (Intelligent Precision Shift) option.
Lotus has taken the award winning* Evora and re-created it with a 350 PS 3.5l V6 engine to create the Evora S. Dany Bahar Lotus’ Chief Executive Officer summed it up beautifully when he said: “You don’t realise what you were missing from your driving experience until you get behind the wheel of the Evora S.”
So apart from the obvious power difference, how is the Evora S different to the standard Evora? It’s another question we put to the CEO (given that he’s spent a little time behind the wheel, we thought he’d be best placed to answer questions). This is what he said: “It’s the next level of Evora experience. It communicates with you better, the suspension setting has been fine tuned for added power and control so it responds even more to direction. It’s an instinctual car, the experience is pure.”
“We were proud of the Evora but we’re even prouder of the Evora S, I feel like it does the true Lotus experience justice. The really great thing is that as we move forward the standard Evora should also benefit from some of these developments.”
The Evora S comes with a sport pack as standard featuring a ‘sport’ button which allows the driver to control throttle response and activate the exhaust by-pass valve. The sport button also raises the instantaneous rev limit and changes the dynamic stability control settings resulting in a total experience change. There are cross-drilled brakes for improved cooling. And here’s a heads up for those who buy into the old adage ‘you can tell the men from the boys by the size of their toys’: the external emotion of the Evora S has been improved with a completely new active exhaust which means that at the push of a button the car sounds just as dramatic as it feels.
Commenting on the Evora S, Lotus Chief Commercial Officer Andreas Prillmann said: “The Evora S is a natural progression for us but more than that, it’s a taste of what people can come to expect from the next generation of Lotus cars. It retains core Lotus values such as performance through lightweight but it also gives more than that. It’s the perfect combination of top performance, style and comfort. Form doesn’t sacrifice function in the case of the Evora S.”
So there you have it folks, the next generation of Lotus Evora, the Evora S, set to be unveiled at the Paris Motor Show.
But that’s not all. In addition to the Evora S, Lotus also presents the IPS (Intelligent Precision Shift) option. This inception of the seven-time-award-winning (who’s counting? We are!) Evora sees an automatic 6-speed gearbox with Lotus developed transmission control with a 3.5 l V6 engine delivering 280 PS assuring a superior automatic driving experience.
The IPS version of the Evora allows the driver to switch between manual paddle shift and automatic drive modes. The driver also has the option of selecting ‘sport’ mode which showcases the Lotus sport driving experience allowing the driver to really feel each gear shift and be in complete control of the transmission.
Commenting on the development Dany Bahar said: “The Evora IPS is set to broaden the appeal of the Evora and reach out to a slightly different market. We hope it will be popular with established automatic locations such as Asia, the Middle East and the US. It’s been a long time since Lotus created an automatic and we’ve spent a great deal of time refining this one to make sure that it perfectly complements the Evora drive experience.”
Evora S Technical Specification
Model Evora S
Engine Mid mounted, transverse 3.5 litre DOHC V6 VVT-I
Emissions see below due to wheel options
Transmission 6 speed manual
Chassis Modular lightweight bonded aluminium structure
Steering Lotus tuned hydraulically-assisted power steering
Suspension Forged aluminium double wishbone suspension
Bilstein high performance gas dampers
Eibach coaxial coil springs
Performance data
Standard wheel option
Fuel consumption - urban 14.5 l/100km
Fuel consumption – extra urban 7.4 l/100km
Fuel consumption - combined 10.0l/100km
CO2 Emissions 235 g/km
19/20” wheel option
Fuel consumption - urban 14.6 I/100km
Fuel consumption – extra urban 7.6 I/100km
Fuel consumption - combined 10.2 I/100km
CO2 Emissions 239 g/km
Max power 350 PS / 257.5 kW @ 7000 rpm
Max torque 400 Nm / 295 lb ft @ 4500 rpm
0-60 mph 4.6s
0-100 km/h 4.8s
Maximum speed 172mph
Vehicle mass (unladen) 1437kg
Evora IPS Option Technical Specification
Emissions 208 g/km
Transmission Electronically controlled 6 speed automatic
Performance data
Fuel consumption - urban 12.6 l/100km
Fuel consumption – extra urban 6.6 l/100km
Fuel consumption - combined 8.8 l/100km
CO2 Emissions 208 g/km
Max power 280 PS / 206 KW @ 6400rpm
Max torque 350 Nm / 258 lb ft @ 4700rpm
0-60 mph 5.3s
0-100 km/h 5.5s
Maximum speed 155mph
Vehicle mass (unladen) 1436 kg
Zdesign
7ony a écrit :http://www.myspeedster.ch/forum/viewtopic.php?t=19977&postdays=0&postorder=asc&start=120
:shock: :shock: .... :OO:
adrien 69
Message par adrien 69 »
J'avais pas percuté sur le poids...Plus lourd qu'un Cayman S :shock: !
oué c'est pas un missile non plus ...
adrien 69
et puis 1kg de différence entre la 280 et la 350 avec le diffuseur, le compresseur, .... Je suis sceptique.
le compresseur de clim est le meme :areuh:
ludovic
Message par ludovic »
1 440 kg ! c'est plus lourd que ma mégane RS :MDR:
Michadams
Message par Michadams »
adrien 69 a écrit :et puis 1kg de différence entre la 280 et la 350 avec le diffuseur, le compresseur, .... Je suis sceptique.
Les poids donnés sont pour la version auto (280cv) ou S (350cv)...
Une Evora de base, c'est en-dessous de 1350kg, ce qui, je te l'accorde, reste lourd.
La mienne, en 2+0, avec les jantes non forgées, échappement Lotus Sport Stage 1, et un plein a été pesée autour des 1332kg, alors que la presse donne 1380kg (les versions presse étaient des 2+2 full options).
Je ne sais pas où ils vont chercher 100kg....
Même avec un échangeur en plus du compresseur et les jantes en 19/20, vois pas comment on peut prendre 100kg.
Verrai bien le verdict de la balance une fois la mienne compressée...
mais les gars j'crios qu'il y a pas de compresseur sur le v6 de l'évora S moi...
adrien 69
Heu, oui, en effet rien ne le confirme pour l'instant. :jap:
Michadams
Si, l'Evora S est bien une version compressée.
C'est un "oubli" (voulu ou pas) de Lotus dans leur communiqué.
La version qui tournait au ring (Evora rouge) a un compresseur Eaton TVS. Maintenant, vous allez me dire que ce n'est pas l'Evora S mais une future SC?
In : AutoExpress avril 2011
Essai routier complet de l'Evora S
http://www.autoexpress.co.uk/carreviews ... 4850acda8c
PS : trop long pour être traduit :oops:
Oli
Message par Oli »
Toujours pas aussi bien qu'un Cayman S au total, et c'est les anglais qui le disent. :gurk: Et 10k£ de plus que la Porsche, ils sont fous chez Lotus ! :shock: Vraiment dommage, parce qu'elle fait envie...
Michadams
Si, même en atmo, l'Evora est "mieux" qu'un Cayman, même en S.
Ok, si on compare les finitions, la motorisation moins noble, etc. Mais je n'ai pas connaissance d'un Cayman S qui soit descendu sous 2'58 à Spa, alors que je suis en 2'53'02 pour mon meilleur temps et tourne généralement en 2'55/2'56 (tjrs avec un passager).
Là, je ne parle que de faits, de chiffres... Après, y'a le plaisir de conduite, le toucher de volant, les sensations distillées par le chassis, et là, y'a pas de comparaison possible. J'ai pu essayer le Cayman S (320cv), j'ai adoré le moteur, mais pour ce qui est des sensations, il faut une GT3, mais là, c'est le double niv budget.
Je vais en énerver plus d'un en disant ça, mais je comparerais le Cayman dans sa catégorie, à ce que sont les MRS ou GTR dans les leurs. Efficace, mais manque de sensations effrayant.
Puis, un jour, il faut revendre, la décôte Porsche, non merci. Les Evora qu'on trouve en occasion gardent un prix assez élevé. Le premier prix en Europe (hors UK, évidemment) est de 53000€ alors que l'on trouve neuves optionnées (non LE) juste au-dessus de 60K... Et encore, il s'agit de versions LE (Launch Edition) que tt le monde boude pour un tas de raisons (il y avait de gros soucis de finition/assemblage, commande d'embrayage foireuse, pas de boite courte bien que full options, et la plupart on servi de démo avant d'être revendues comme voiture de direction). Pour une bonne Evora non LE, elles sont à partir de 55K !
J'aime bcp le Cayman, j'ai failli craquer 3x, mais y'a rien à faire, l'Evora a beau avoir pleins de petits défauts, je la trouve excellente. Originale vu sa rareté, réussie esthétiquement et le tablau de bord est vraiment sympa là où celui du Cayman est terne, bien que mieux fini et certaiement plus pratique/ergonomique. Puis, vous trouvez l'Evora chère, mais la liste d'options reste limitée, et il y a moyen de négocier pas mal. Pour le Cayman, faut quasi rajouter 20 à 25% du prix de la voiutre en options avec un magnifique porte-clés en guise de remise...
Se baser sur des essais presse pour parler d'une voiture ou encore pire, la comparer à une autre, c'est un peu stupide... J'ai lu des essayeurs qui "bandaient" pour une Berlingo ou pour une Passat... J'ai également lu des essais d'Elise/Exige qui y obtenaient des "résultats" hyper décevants, tout dépend de ce que l'on aime/désire/recherche. Les testeurs sont des êtres humains, avec ces mêmes envies... L'Evora a qd même été élue sportive de l'année, c'est pas pour rien.
Une Porsche, c'est une GT3, point-barre :D
Myka
adrien 69
http://www.lacentrale.fr/auto-occasion- ... 79520.html
Boite courte pourtant :voyons: .
Un cayman S même année et +/- même km....
http://www.lacentrale.fr/auto-occasion- ... 69845.html
Pourtant je suis pro Evora même si j'ai jamais testé. :areuh:
Michadams a écrit :.... Mais je n'ai pas connaissance d'un Cayman S qui soit descendu sous 2'58 à Spa, alors que je suis en 2'53'02 pour mon meilleur temps et tourne généralement en 2'55/2'56 (tjrs avec un passager)
Ca ne me semble pas très pertinent comme remarque sachant que la très grande majorité des possesseurs d'Evora et de Cayman S ne mettent pas les pieds sur circuit...
Michadams a écrit :... Puis, un jour, il faut revendre, la décôte Porsche, non merci. Les Evora qu'on trouve en occasion gardent un prix assez élevé...
Beaucoup trop tôt pour juger, let's wait and see.
Michadams
Ce n'est pas une boite courte, bien que ce soit indiqué. Aucune Launch Edition n'avait la boite courte. Puis c'est une ex-démo qui a été "bradée" au premier acheteur (comme toutes les LE), qui lui-même la remise...
Et pour le Cayman, c'est un version spéciale, et au vu des options, elle a du être facturée autour des 80/85K.
Je connais la cote des deux voitures, je cherche à revendre l'Evora pour une S et j'ai lorgné sur le Cayman S et donc, les occasions en même tps...
Avec ce type de voitures, que ce soit Porsche, Lotus et les autres, ce n'est jamais un achat raisonnable, et la raison première est se faire plaisir, et sur ce point, du moins, pour ma part, qui ne cherche (quasi) uniquement les sensations, mon choix est fait et bientôt refait :D
Michadams
Détrompe-toi, il n'y avait qu'à voir le Lotus Day à Spa, il y avait une grosse dizaine d'Evora... Et puis, sans vouloir te vexer, t'es un peu mal placé pr parler de pertinence avec une Exige Cup qui n'a jamais mis une roue sur piste ;)
Michadams a écrit :Détrompe-toi, il n'y avait qu'à voir le Lotus Day à Spa, il y avait une grosse dizaine d'Evora... Et puis, sans vouloir te vexer, t'es un peu mal placé pr parler de pertinence avec une Exige Cup qui n'a jamais mis une roue sur piste ;)
Au contraire, je trouve ceci très pertinent... imagine bien que si une Cup ne met pas les roues sur circuit, ce doit être bien pire pour les vieux bourges qui roulent en Evora ou Cayman :MDR:
Michadams
Ben, y'a des Cayman récents, et les prix sont très bas par rapport au tarif neuf... Une Evora ne perdra jamais 60/70% de sa valeur comme peuvent le faire un Boxter ou Cayman au bout d'un certain temps.
Michadams
Encore une fois, tu aurais vu le nombre de "vieux bourges" en Evora à Spa, tu en serais honteux :MDR:
Michadams a écrit :... Une Evora ne perdra jamais 60/70% de sa valeur comme peuvent le faire un Boxter ou Cayman au bout d'un certain temps.
J'adore tes certitudes concernant l'Evora, surtout après seulement 15 mois de commercialisation
Michadams
20mois, même ;)
Aucune Lous n'a connu une décote aussi importante, pourquoi l'Evora serait-elle dans le cas?
Aucune Lotus, vraiment ?
Pour n'en citer que quelques-unes : Excel, Elite, Eclat et plus récemment Europe...
Oli
Message par Oli »
Michadams a écrit :Se baser sur des essais presse pour parler d'une voiture ou encore pire, la comparer à une autre, c'est un peu stupide...
Mouais, mais quand tous les essais/comparatifs presse disent la même chose, ce n'est pas parce qu'il y a un fond de vérité ? L'Evora a sûrement beaucoup de qualités, mais elle a aussi de gros défauts, surtout comparé au Cayman. Cette dernière manquerait cruellement de sensations ? Tu as dû essayer un modèle foireux, parce que j'en ai essayé deux et je n'ai pas du tout eu cette impression, j'ai même beaucoup aimé. Mais il faut aussi les bonnes options pour pouvoir en profiter pleinement. Ceci dit, le plaisir de conduite pur a l'air d'être le point fort de cette Evora. Mais ici, des anglais qui conseillent le Cayman plutôt que l'Evora (la S en plus !), ça m'a vraiment étonné...
Pour la décote, il est effectivement un peut tôt pour se prononcer... Je pense qu'après quelques années, elle va perdre au moins autant que la Porsche, je ne vois pas pourquoi ce ne serait pas le cas.
Oli
Message par Oli »
Voilà des chronos qu'on peut vraiment comparer :
http://www.sportauto-online.de/vergleic ... 06556.html
Sur le circuit court d'Hockenheim :
Audi TTRS : 1'14"3
Lotus Evora : 1'14"3
Porsche Cayman S : 1'14"0
On peut quand même souligner la performance de l'Evora qui est très proche avec 40ch de moins, même si un peu plus légère. Mais sur un circuit rapide comme Spa, la différence de perfs devrait être plus sensible, donc le Cayman S devrait creuser un plus gros écart.
adrien 69
Donc la S devrait prendre l avantage. :-><:
Michadams
Mouais, mais quand tous les essais/comparatifs presse disent la même chose, ce n'est pas parce qu'il y a un fond de vérité ? L'Evora a sûrement beaucoup de qualités, mais elle a aussi de gros défauts, surtout comparé au Cayman. Cette dernière manquerait cruellement de sensations ? Tu as dû essayer un modèle foireux, parce que j'en ai essayé deux et je n'ai pas du tout eu cette impression, j'ai même beaucoup aimé. Mais il faut aussi les bonnes options pour pouvoir en profiter pleinement...
C'est toujours ds l'interet d'une concession de proposer l'essai d'une voiture "foireuse" à un éventuel acheteur... Je peux te retourner la chose, as-tu essayé l'Evora?
Dans l'absolu, c'est clair que le Cayman est excellent, mais pour ma part, je le comparais à l'Evora et sur ce point, le Cayman est moins jouissif. Si ce n'est son moteur et sa boite, l'ensemble Toy est vraiment "pourri" à côté. Maintenant, un temps ne sert de référence qu'en compétition, et à ce niveau seul le pilote ferait une différence. Et rien que pour les sensations distillées en premanence, je préfère l'Evora au Cayman, au quotidien, comme sur piste, que je me prenne une seconde...ou pas.
Et la S, c'est encore autre chose, j'ai pu l'essayer, la voiture estvraiment métamorphosée! Même la version IPS (auto) qui pourtant fait 280cv comme l'atmo, c'est à n'y rien comprendre, ça pousse bien plus fort que mon Evora.
Sincèrement, essayez d'en faire un essai, elles se vendent mal, il devrait etre facile de pouvoir en faire un, et une fois qu'elles seront autour des 45K, ce sera de super bonnes affaires (tjrs pr les non LE).
Anthony
Message par Anthony »
Concernant les aptitudes à mener une auto tel qu'une Evora ou Chepor (en plus sur le tracé de Spa), vous pouvez faire confiance à Myka, c'est tout sauf un manchot! :D :-><:
